  • Io Audio Technologies Announces Release of new 1/4in Phone Jack Series in Full- or Half-Threaded Options
Apr 05, 2023
New Yorker Electronics supplies Io Audio Technologies New TJ Series of ¼-inch Phone Jacks in Full-Threaded or Half-Threaded nose versions
New Yorker Electronics Set to Distribute Io Audio’s Tiny Jack (TJ) Series  with Switched-contact Design Making them Ideal for Design-in Applications
NORTHVALE, New Jersey, USA  – New Yorker Electronics has announced Io Audio Technologies’ release of the new Tiny Jack (TJ) Series of Horizontal PCB 1/4in Phone Jacks in Full- or Half-Threaded nose versions. The TJ Series features a slim design with a high packing density in black, plastic housing for audio and control.
Offering both full and half-threaded options accommodates a wide range of panel thicknesses. The Io Audio TJ Phone Jack series provides a switched-contact design making them appropriate for design-in applications where the termination method is to a printed circuit board and where the independent control of switched contacts is required. The compact form factor of these connectors makes them applicable in situations where space saving is a priority or space for a connector is limited. Both versions fit an 11.4mm chassis cutout.
The full-threaded version is available with silver-plated pins in 4-pin Mono-Switched (IO-TJ4HF) and 6-pin Stereo-Switched (IO-TJ6HF) options and half threaded in IO-TJ4HH and IO-TJ6HH.
Features & Benefits:
  • Contacts: 4 (IO-TJ4HF) or 6 (IO-TJ6HF)
  • 3 Normally Closed Switched Contacts
  • Operating temp: -25°C ~ +70° C
  • Insertion Force: 5-30N
  • Lifetime: > 5000 Mating Cycles
  • Contact Resistance: < 30mω
  • Insulation Resistance: ≥ 100Mω
  • Dielectric Strength: 500VAC @ 60s
Applications:
  • Installations
  • Communications
  • Pro AV
  • Medical
As a franchise distributor, New Yorker Electronics supplies the full inventory of Io Audio Technologies commercial, residential, broadcast and stage Cables, Connectors and Bulk Wire.
About New Yorker Electronics
Headquartered in Northvale, NJ, New Yorker Electronics, Co., Inc. (www.newyorkerelectronics.com) is a global franchised distributor of electronic components, value-added services, and supply chain solutions to the world’s leading OEMs and contract manufacturers in various markets. Founded in 1948, the AS9120B and ISO 9001:2015 certified company has earned a reputation for delivering superior levels of reliability and customer support while providing direct franchise access to an extensive ready-to-ship inventory of passive, inter-connect, electromechanical and Mil-Spec components, as well as semiconductor devices.
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Apr 03, 2023 -
Vishay Intertechnology High-Temperature IHSR Inductor Delivers Current Ratings to 155A
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Io Audio Technologies Announces Release of new 1/4in Phone Jack Series in Full- or Half-Threaded Options news release has been viewed 963 times
Facility Closure
