Advantages of ultrasonic spraying for photoresist
Nov 18, 2020
Photoresist Coating
Ultrasonic spraying technology is used for semiconductor photoresist coating. Compared with traditional coating processes such as spin coating and dip coating, it has the advantages of high uniformity, good encapsulation of microstructures, and controllable coating area. In the past 10 years, it has been fully demonstrated that the 3D microstructure surface photoresist coating using ultrasonic spraying technology, the prepared photoresist coating is significantly higher than the traditional spin coating in terms of microstructure wrapping and uniformity Craft.
The ultrasonic spraying system can precisely control the flow rate, coating speed and deposition volume. Low-speed spray shaping defines atomized spray as a precise and controllable pattern to avoid excessive spray when producing a very thin and uniform layer. The ultrasonic spray system can control the thickness from sub-micron to more than 100 microns, and can coat any shape or size.
http://www.cheersonic-liquid.cn/en/photoresist-coating/
Application
Ultrasonic spraying system can be used for surface coating of flat and 3D structural substrates including silicon wafers, glass, ceramics, metals and other materials. Typical photoresist coating applications include wafers, MEMs, lenses, microfluidic chips, filters and many more.
Advantages of ultrasonic spraying for photoresist:
• High uniformity and uniformity
• Non-contact spraying
• Micro-flow spraying, multiple liquid feeding schemes
• High speed control accuracy
• High liquid utilization
• High flexibility in chemical and coating performance.
• Non-clogging atomized spray.
• High transmission efficiency and minimal waste.
• Highly repeatable mature spraying process.
About Cheersonic
Cheersonic is the leading developer and manufacturer of ultrasonic coating systems for applying precise, thin film coatings to protect, strengthen or smooth surfaces on parts and components for the microelectronics/electronics, alternative energy, medical and industrial markets, including specialized glass applications in construction and automotive.
The Company’s solutions are environmentally-friendly, efficient and highly reliable, and enable dramatic reductions in overspray, savings in raw material, water and energy usage and provide improved process repeatability, transfer efficiency, high uniformity and reduced emissions.
Cheersonic’s growth strategy is focused on leveraging its innovative technologies, proprietary know-how, unique talent and experience, and global reach to further develop thin film coating technologies that enable better outcomes for its customers’ products and processes. For further information, visit https://www.cheersonic-liquid.cn/en/.
Nov 27, 2020 -
Ultrasonic Spray For Electrode Coating
Nov 27, 2020 -
Improving Fuel Cell Performance With AI
Nov 27, 2020 -
Does hydrogen energy really work?
Nov 27, 2020 -
Will hydrogen energy vehicles eventually replace lithium batteries?
Nov 24, 2020 -
The ultrasonic spray dryers are targeted for laboratory applications.
Nov 24, 2020 -
Maximizing the use of GDL in the Fuel Cell by ultrasonic spray application
Nov 24, 2020 -
Research on non-precious metal catalysts. Research progress of non-precious metal catalysts for proton exchange membrane fuel cells
Nov 17, 2020 -
Ultrasonic Coating System For Fuel Cell Manufacturer
Nov 16, 2020 -
Coating Photoresist Onto MEMS
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Advantages of ultrasonic spraying for photoresist news release has been viewed 631 times
