  • Engineered Material Systems Debuts CA-180 Low-Temperature Cure Conductive Adhesive
May 04, 2015
CA-180 Low-Temperature Cure Conductive Adhesive.
Engineered Material Systems, a leading global supplier of electronic materials for circuit assembly applications, introduces its newest conductive adhesive – CA-180. The low-temperature cure conductive adhesive has been designed for die attach and general circuit assembly applications.
CA-180 cures in 30 minutes at 80°C, three minutes at 100°C or 10 seconds at 150°C with an electrical conductivity of 4 x 10-5 ohm-cm. Applications where the components are temperature-sensitive and require high conductivity interconnects are ideal for this material. CA-180 has a 48-hour work life and a 12,000 cP viscosity at 5 rpm for easy needle dispensing or application by pin transfer.
CA-180 was developed to pass the rigorous reliability requirements in die attach, disk drive, camera module, photonics and circuit assembly applications. CA-180 is the latest addition to Engineered Material Systems’ extensive line of electronic materials for semiconductor, circuit assembly, photovoltaic, printer head, camera module, disk drive and photonic applications.
For more information about the CA-180 low temperature curing adhesive or to learn how Engineered Material Systems can define, develop and create an engineered material solution that is right for your company, visit www.emsadhesives.com.
Dec 04, 2019 -
Jun 15, 2019 -
May 13, 2019 -
Apr 15, 2019 -
Feb 21, 2019 -
Jan 15, 2019 -
Sep 27, 2018 -
Sep 13, 2018 -
Sep 05, 2018 -
Jun 11, 2018 -
Jun 07, 2024 -
Jun 06, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Engineered Material Systems Debuts CA-180 Low-Temperature Cure Conductive Adhesive news release has been viewed 1216 times
