  • Multitest Develops Innovative LCR Concept for Cost Efficient, High-Performance Test Interface Boards
Nov 24, 2010
Santa Clara, CA - Multitest's board division has successfully introduced a new LCR (layer count reduction) concept for high pin count BGA applications. Board customers now will benefit from significant cost savings without sacrificing performance. With the new LCR concept, the layer count of standard pitch BGA boards can be reduced by up to 40 percent.
Board thickness often is a mechanical issue in terms of docking height and/or connector requirements. Other approaches used to slim down boards, such as using thinner cores, are limited due to manufacturability and performance.
With the company’s design-to-delivery PCB services, Multitest leverages the unique capabilities of its board fabrication site and the extraordinary expertise of its design team. DFM (design for manufacturability) guidelines have been developed, allowing board designers to reduce both the signal layers and the necessary ground planes.
The design rules for LCR have been characterized by Multitest’s signal integrity team to ensure performance: the diameter of the antipads, vias and tracing geometries are proven to have no negative impact on PCB performance.
To learn more about the advantages of Multitest’s board services, visit http://www.multitest.com/boards.
Multitest (headquartered in Rosenheim, Germany) is one of the world’s leading manufacturers of test equipment for semiconductors. Multitest markets test handlers, contactors, and ATE printed circuit boards. Globally, more than 700 employees serve the company’s customers in offices and branches in North America, Singapore, Malaysia, the Philippines, Taiwan, China and Thailand.
www.multitest.com
Mar 29, 2018 -
Mar 13, 2018 -
Dec 16, 2013 -
Dec 02, 2013 -
Nov 25, 2013 -
Nov 18, 2013 -
Nov 11, 2013 -
Sep 09, 2013 -
Aug 22, 2013 -
Jul 15, 2013 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Multitest Develops Innovative LCR Concept for Cost Efficient, High-Performance Test Interface Boards news release has been viewed 783 times
