  • Perllo Technologies Introduces Extec�s new line of Steel-Inked and 3-D Thick Film Hybrid Technology into US Marketplace
Nov 19, 2004
Thick Film Inks On Steel
Pressure Sensor
Pressure Sensor
St. Charles, IL November 1, 2004 - Perllo Technologies LLC is pleased to announce its new partnership with Extec Integrated Systems Limited ("Extec") of Hampshire, United Kingdom. Together, these two pioneering companies provide industry leaders in Aerospace, Military Defense, and Space technology and design, access to Extec�s expertise in innovative solutions and hybrid microcircuits facilitated by Perllo Technologies� superior logistics options and unsurpassed customer service. Extec has been an industry leader in the design and manufacturing of Thick Film Hybrid microcircuits for over 18 years. Using Thick Film Hybrid technology, Extec has perfected innovative techniques in the manufacturing and development of Thick Film inks onto steel for use in pressure sensors, Peltier (thermo-electric) Coolers, and 3-Dimensional structure applications. Standard Thick Film technology has a ceramic substrate sequentially screen printed with precious metal and di-electric inks, producing a multi-layer interconnected pattern. The layered pattern is then dried and fired at 850�C to form a bond to the substrate. Resistors are also printed onto the pattern where they are then laser trimmed to better than 0.5% accuracy. Once the printed substrate is complete, components can be added either in the form of semiconductor die and chip capacitors (which are epoxy attached), or Small-Outline surface-mount devices and capacitors (which are soldered down). After the components are attached, they are wire-bonded into circuit using gold or aluminum 0.001" diameter wire, thus completing the circuit and making it ready for testing.
A typical pressure sensor will have a Wheatstone Bridge printed onto an area of the steel, such that deflection of the steel either by applied pressure or mechanical force will cause a distortion of the resistors in the bridge and a consequent change in value. This change will cause a detectable output from the bridge.
Extec�s new advancements in steel pressure sensors allow for the particular advantage of e-beam welding to a variety of fixtures to suit any application. This e-beam welding effectively minimizes stress caused to the bridge�s diaphragm and has resulted in exceptional linearity with minimal to zero hysteresis. Frank Bellion, Extec�s Technical Director explains, "When we first saw the linearity results from the steel sensors, we did not believe the graph; it looked as though someone had drawn a straight line and then added the measurement points to it!". Peltier Coolers are another application where Extec has used Thick Film ink technology on steel. Extec has designed and fabricated many Peltier Coolers ranging in size from very small to several inches long to suit a variety of applications. One advantage of these Coolers is that the steel substrate becomes the heat sink, thus removing one layer of thermal resistance. Combining Thick Film printing onto the top face of a Cooler can provide an electronic circuit with its own heat dissipater. Chris Warne, Extec�s Managing Director, states "We have seen an enormous interest in providing tailor-made Peltier Coolers for our customer�s specific applications including Coolers for infrared diodes, high-dissipating electronic circuitry, and even beer dispensing pumps. We have been able to provide custom Peltiers of better efficiency, both in terms of mechanical effectiveness and superior specification, than those available off the shelf."
Another Extec advancement has been to use Thick Film technology to form 3-D structures on ceramic substrate by printing a release-layer as a first-process step. This release layer can cover the entire substrate (if the whole circuit is required to be released) or be printed only under isolated areas (if only parts of the structure are to be released). Printing of the substrate is then carried on as normal until the circuit has been built up, finally allowing the release layer to be removed. The remaining layers may be attached to the surrounding structure forming movable elements, or can be completely released forming a multi-layer circuit only microns thick. John Holliman, Extec�s Principal R & D Engineer, states, "When we discovered that we could release entire structures from the underlying ceramic we were very excited; the applications for this technique in the area of sensors are quite enormous. We have already successfully produced pressure sensors, accelerometers and Carbon Monoxide gas detectors and are finding new applications for our customer�s needs all the time."
Perllo, founded in 2002, is headquartered in St. Charles, Illinois. The company specializes in engineering design, manufacturing, product management, transportation, and warehousing to provide our clients the best possible product, service and delivery. For additional information, please visit our website: http://www.perllo.com.
Extec Integrated Systems was formed in 1986, and is headquartered in the United Kingdom. The company is an expert in providing design and manufacturing of Thick Film Hybrid microcircuits. With a strong emphasis on engineering, Extec is also able to offer innovative new products including ultra fine-line technology, power and optical products. For addition information, please visit http://www.extec.uk.co.
Nov 19, 2004 -
New Line of Inductors Offers Lead Free Option for Automotive and Industrial Control Applications
Nov 19, 2004 -
New Technology Allows Ignition Coils a Longer Life
Nov 19, 2004 -
Micro-Miniature Transponder Coil Offers Solutions for Automotive Applications
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Perllo Technologies Introduces Extec�s new line of Steel-Inked and 3-D Thick Film Hybrid Technology into US Marketplace news release has been viewed 1091 times
