Flextac Self-Adhesive Stencils Simplify BGA Rework
Feb 26, 2001
Innovative Flextac Stencils simplify BGA rework. These self-sticking laser cut, polymer solder paste stencils use a residue-free adhesive similar to Post-it Notes to seal around BGA pads to ensure that solder paste will not bleed under the stencil when the paste is applied. Disposable Flextac Stencils are easy to use and will not leave any residue on the board surface. Currently, BGA rework stencils are fabricated from metal and require fixturing or taping to position them and hold them in place. They warp easily, and if the circuit board has undulations in the board surface, a metal stencil will not sit flat against the surface. Since there is no gasket-like seal, solder paste can easily bleed under metal stencils when paste is applied with a squeegee. Solder paste can also spill out over the sides of flat metal stencils contaminating the circuit board surface.
Innovative Flextac Stencils are laser cut from a high quality, anti-static polymer film that is the same thickness as metal stencils. If the Flextac Stencil is not correctly positioned, it can simply be removed and repositioned. Side tabs serve as solder dams, preventing overspill. No external taping or fixturing is used to hold Flextac Stencils in place. Since the self-tack adhesive seals around each BGA pad, the operator can make as many passes as necessary with the squeegee to assure proper aperture filling with solder paste. The Flextac Stencil is then peeled up leaving a perfect deposit of solder on each pad.
Although Flextac Stencils are disposable, they can be used several times. They eliminate tedious stencil cleaning and reduce operator exposure to solder paste.
Nov 13, 2023 -
Circuit Technology Center Announces New Component Trim and Form Service
Jul 19, 2023 -
Whitepaper Discusses Critical Process Steps for High-Reliability BGA Device Re-balling
Nov 12, 2021 -
Circuit Technology Center Releases Updated Bonding System
Aug 13, 2021 -
Circuit Technology Center Commissions New XRF X-ray System
Nov 12, 2008 -
Breakthrough Concept to Bond Circuit Board Jumper Wires
Aug 09, 2001 -
Base Board Repair Kit Has �Everything Needed� To Repair Most Types of Damage to Circuit Boards
Jun 11, 2001 -
Professional Repair Kit, the �Total Package� for Repairing Damaged Circuit Boards
May 02, 2001 -
Update Operator Certification with the IPC 7711 Rework Skills Certification Kit
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Flextac Self-Adhesive Stencils Simplify BGA Rework news release has been viewed 1159 times
