KDPOF Introduces POF Link for Telematics Control Module
Apr 24, 2019
KDPOF presents an optical link concept with Gigabit Ethernet over POF for telematics control modules
Optical Gigabit Connectivity Secures High Electromagnetic Compatibility
KDPOF – leading supplier for gigabit transceivers over POF (Plastic Optical Fiber) – presents an optical link concept for telematics control modules. "Several OEMs choose the IEEE Std 802.3bv™ for Gigabit Ethernet over POF (GEPOF), which is the ideal solution to connect Smart Antenna to the central communications hub while avoiding electromagnetic interference (EMI)," explained Carlos Pardo, CEO and Co-founder of KDPOF. "The optical link enhances antenna performance, whereas in conventional systems, antenna reception sensitivity is reduced by the radiated emissions coming from the electrical communications links, such as UTP (Unshielded Twisted Pair) copper cables, coax, and the shielded alternatives." KDPOF, in partnership with ALPS, has developed a concept for an LTE-A telematics control module that uses Gigabit Ethernet over POF to connect to the central communications hub such as a head unit. Since POF provides inherently high Electromagnetic Compatibility (EMC), the links do not interfere with the smart antenna receivers. With the necessary speed going beyond 100 Mbps, a 1 Gbps Ethernet link is required. Moreover, substituting the current RF link with an Ethernet data link will not only aggregate LTE-A packets but other sources such as digital radio as well.
Optical Link Concept for Smart Antenna
New plastic, composite and crystal roofs or roofs with openings do not shield the antenna from electromagnetic noise generated inside the car compartment. Instead, a significant amount of energy is radiated by the coaxial cable that is coupled back into the Integrated Smart Antenna (ISA) electronics, which severely degrades its performance. The natural EMC problem-free POF is ideally suited for an Ethernet connection, avoiding back-coupling conditions like the above mentioned one. In addition, the EMC problem-free link permits simple re-positioning of the antenna module among vehicle configurations. Another advantage is the simple integration with current ISA chipsets thanks to the Ethernet (SGMII/RGMII) host bus of the Gigabit POF transceiver. Furthermore, thanks to the Gigabit capacity of the Ethernet link over POF, the data link will aggregate various data streams such as LTE-A, Wi-Fi, V2x, RDS, DAB radio, etc.
KDPOF will present their optical link concept with Gigabit Ethernet over POF for telematics control modules at the Nikkei Tech Days on June 5 and 6, 2019 in Osaka, Japan.
Apr 26, 2024 -
KDPOF Collaborates with Hinge Technology
Oct 04, 2023 -
TRUMPF and KDPOF showcase first 980nm automotive multi-gigabit interconnect system
Jun 28, 2023 -
ICs Made in Spain by KDPOF
Jun 07, 2023 -
KDPOF Celebrates IEEE 802.3cz-2023 Standard for Automotive Multi-gigabit Ethernet over Fiber Optics
Mar 08, 2023 -
KDPOF Endorses IEEE 802.3cz Standard Entering the Finishing Straight of Final Release
Mar 01, 2023 -
Automotive: KDPOF and Würth Elektronik Cooperate for Optical Multi-gigabit Ethernet
Nov 07, 2022 -
First Optical Automotive Ethernet Transmitter Test Demo Displays Proof of Concept for Multi-gigabit Data Connectivity
Sep 26, 2022 -
Automotive Gigabit Ethernet Switch EVB9351-AUT-SW-NXP with Optical Ports
Sep 07, 2022 -
TRUMPF and KDPOF Become Strategic Partners for Automotive Data Communications
Jul 27, 2022 -
KDPOF Designs First Optical 1000BASE-RH SFP Module for Automotive Ethernet
20 more news from KDPOF »
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
KDPOF Introduces POF Link for Telematics Control Module news release has been viewed 901 times
