  • PennEngineering® Awarded U.S. Patent for Unique Heat Sink Mounting System
Sep 22, 2015
Heat sink mounting system from PennEngineering, which has been awarded a U.S. patent for the technology.
PennEngineering® has been awarded U.S. Patent No. 9,113,567 for a unique three-piece heat sink mounting system designed to securely attach heat sinks to printed circuit boards while providing firm and constant contact to the chip component for optimized heat dissipation.  The inventor of this dynamic mounting system is Robert F. Stotz, Jr.
The patented mounting system consists of PEM® Type HSCB™ captivating screw and PEM Type HSL™ spring mated to a PEM Type HSR™ broaching receptacle nut or standoff.  The screw and spring mount together permanently into a heat sink and the receptacle nut/standoff mounts permanently to a printed circuit board.
After the screw and spring are captivated during the installation process, the heat sink can be attached easily to the board by simply tightening the screw into the receptacle nut/standoff.  An audible “click” serves to prevent over tightening by signaling when the screw is fully engaged and installation is complete.  (The screw will continue to rotate but will no longer be engaged in the threads or continue to actively tighten.)  The reliable and repeatable clamp force generated by the spring ultimately helps determine consistent and predictable clamp load on printed circuit board components.
Type HSCB screws and Type HSR broaching nuts or standoffs can be specified in thread sizes #4-40 to #6-32 / M3 and in various lengths.  Screws can be installed into aluminum or steel sheets as thin as .040” / 1mm and nuts/standoffs can be broached into boards as thin as .060” / 1.53mm.
Headquartered in Danboro, PA, USA, PennEngineering develops and manufactures precision fasteners and systems, specializing in thin sheet attachment solutions.  The Company operates fastener manufacturing facilities and key sales offices in North America, Europe, and Asia and is supported by a worldwide network of authorized engineering representatives and distributors.  Visit www.pemnet.com
Contact Leon M. Attarian, PennEngineering®, 5190 Old Easton Road, Danboro, PA 18916-1000 USA.  Tel: +1-215-766-8853.   www.pemnet.com
Feb 26, 2019 -
New PEM SMTSK Standoff Fasteners for Printed Circuit Board Applications
Oct 25, 2016 -
PEM® Fasteners for Printed Circuit Board Applications
Jan 07, 2016 -
Expanding Line of PEM® ReelFast® Surface Mount Fasteners Offers Variety of Reliable Attachment Solutions for Printed Circuit Boards
Oct 15, 2015 -
New PEM® ReelFast® Surface Mount Spring-Loaded Captive Panel Screws for Printed Circuit Boards
Jul 06, 2015 -
PennEngineering® Awarded U.S. Patent for Panel Fastener with Hold-Down Ring
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
PennEngineering® Awarded U.S. Patent for Unique Heat Sink Mounting System news release has been viewed 912 times
Facility Closure
