  • Engineered Conductive Materials Debuts DB-1538-2 Ribbon Attach Conductive Adhesive
Jul 06, 2011
Engineered Conductive Materials, LLC, a leading global supplier of conductive interconnect materials for photovoltaic applications, introduces its DB-1538-2 Conductive Stringer Attach Adhesive, which is designed for use in thin-film, organic and thinned silicon solar modules.
The DB-1538-2 Conductive Stringer Attach Adhesive is available as a one- or two-part adhesive. Companies that want to save money on dry ice shipments and -40°C storage of one-part systems easily can meter-mix the two-part DB-1538-2, which has a 100 to 20 mix ratio by volume. The DB-1538-2 features low bleed on AZO and other transparent conductive oxides while maintaining optimized rheology for dispensing, and excellent damp heat resistance and conductivity stability on tin, tin-silver and silver-plated ribbons. The DB-1538-2 series absorbs stress to withstand thermal cycling from -40°C to 85°C as required for IEC certification,
DB-1538-2 is the latest addition to Engineered Conductive Materials’ full line of conductive stringer attach adhesives, conductive adhesives for back contact crystalline silicon, thin-film and via fill applications, as well as conductive grid inks for photovoltaic applications.
For more information about the DB-1538-2 Conductive Stringer Attach Adhesive or to learn how Engineered Conductive Materials can define, develop and create an engineered material solution that is right for your company, visit www.conductives.com.
Engineered Conductive Materials, LLC (ECM) is a wholly-owned company of Engineered Materials Systems, Inc. (EMS). ECM’s technology focus is electronic circuit fabrication that compliments EMS’s circuit assembly product line. The company creates continual improvements that will guide its customers into the future.
Nov 15, 2016 -
Engineered Materials Systems Introduces Fast Cure Conductive Adhesive for Small- to Medium-Size Chip Bonding
Oct 06, 2016 -
Engineered Material Systems to Showcase Liquid and Dry Film Negative tone Photoresists at Semicon Europa
May 09, 2016 -
Engineered Material Systems to Showcase Adhesives for Stringing and Shingling Next Generation Solar Modules at Intersolar/EU PVSEC
Aug 23, 2015 -
Engineered Material Systems to Show Its New Conductive Adhesive for Stringing HIT and Multi Bus Bar Solar Modules at EU PVSEC
Feb 26, 2013 -
Engineered Material Systems Introduces Die Attach for Temperature-Sensitive Applications
Jan 21, 2013 -
Engineered Material Systems Introduces New Low-Temperature Cure Die Attach
Dec 04, 2012 -
Engineered Conductive Materials Introduces Low-Cost, Flexible Conductive Adhesive CA-141
Nov 27, 2012 -
Engineered Conductive Materials to Discuss New ECA Technology at the 8th CSPV Workshop in Shanghai
Nov 27, 2012 -
Rocket EMS Awarded ISO 13485:2003 Certification
Nov 02, 2012 -
Engineered Conductive Materials’ Chief Technical Officer to Discuss New ECA Technology at the MWT Back Contact Workshop in Amsterdam
8 more news from Engineered Conductive Materials, LLC »
Jun 11, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
James Will to Lead USPAE as New Executive Director
Engineered Conductive Materials Debuts DB-1538-2 Ribbon Attach Conductive Adhesive news release has been viewed 938 times
