  • Vishay Siliconix Announces New PolarPAK Double-Sided Cooling MOSFETs
Dec 15, 2005
Vishay Intertechnology, Inc. today announced that it is shipping the first two power MOSFETs to be offered in its innovative PolarPAK package, which uses double-sided cooling to reduce thermal resistance, package resistance, and package inductance for a more efficient, faster-switching power MOSFET.
PolarPAK was specifically designed for easy handling and mounting onto the PCB with high-speed assembly equipment, thus enabling high assembly yields in mass-volume production. This is one reason why PolarPAK has already earned the distinction of being the first MOSFET package with double-sided cooling to be sourced by multiple manufacturers, beginning with a license agreement concluded between Vishay and STMicroelectronics in March 2005.
The first PolarPAK power MOSFETs are the 30-V n-channel SiE802DF and SiE800DF. Optimized for the low-side control switch in synchronous rectification dc-to-dc converters, the SiE802DF offers exceptionally low on-resistance of 1.9 milliohms maximum at a 10-V gate drive (2.6 milliohms maximum at 4.5 V) and can handle current levels up to 60 A. The SiE800DF, optimized to work as the low-duty-cycle high-side MOSFET in synchronous dc-to-dc converter designs, features a very low typical gate charge Qg of 12 nC, with on-resistance of 7.2 milliohms maximum at 10 V and 11.5 milliohms at 4.5 V.
The new PolarPAK power MOSFETs, which have the same footprint dimensions of the standard SO-8, dissipate 1 degree Celsius per Watt from their top surface and 1 degree Celsius per Watt from their bottom surface. This provides a dual heat dissipation path that gives the devices twice the current density of the standard SO-8. With its improved junction-to-ambient thermal impedance, a PolarPAK power MOSFET can either handle more power or operate with a lower junction temperature. A lower junction temperature means a lower rDS(on), which in turn means higher efficiency. A reduction in junction temperature of just 20 degrees Celsius can also result in a 2-1/2 times increase in lifetime reliability.
Typical applications for the new PolarPAK devices include voltage regulator modules in notebook and desktop PCs, and other systems requiring high-efficiency dc-to-dc conversion. By delivering superior thermal performance and reducing package-related losses, the 5-mm by 6-mm PolarPAK package allows designers to create smaller, more compact circuit designs with a lower component count. With a height dimension of just 0.8 mm, half the height of the SO-8, the PolarPAK package enables end products that are thinner as well.
Samples and production quantities of the SiE800DF and SiE802DF are available now, with lead times of 10 to 12 weeks for larger orders. Pricing in 10,000-piece quantities starts at $1.00 per piece for the SiE802DF and $0.80 per piece for the SiE800DF.
Vishay Intertechnology, Inc., a Fortune 1,000 Company listed on the NYSE (VSH), is one of the world's largest manufacturers of discrete semiconductors (diodes, rectifiers, transistors, and optoelectronics) and selected ICs, and passive electronic components (resistors, capacitors, inductors, and transducers). Vishay's components can be found in products manufactured in a very broad range of industries worldwide. Vishay is headquartered in Malvern, Pa., and has operations in 17 countries employing over 25,000 people. Vishay can be found on the Internet at http://www.vishay.com.
PolarPAK is a registered trademark of Siliconix incorporated
Editor resources:
Links to product datasheets:
http://www.vishay.com/doc?73199 (SiE800DF)
http://www.vishay.com/doc?72985 (SiE802DF)
Link to product photo:
http://www.wallstcom.com/vishay/sie800df.zip
Editorial contact:
Bob Decker, Wall Street Communications (+1 415 409-0233, bob.decker@wallstcom.com)
Reader contact:
E-mail: info@vishay.com
Web: http://www.vishay.com
Phone (samples): 1 619 336-0860
Jul 06, 2010 -
Feb 14, 2007 -
Feb 14, 2007 -
Feb 24, 2006 -
Feb 24, 2006 -
Feb 24, 2006 -
Dec 06, 2005 -
Dec 06, 2005 -
Nov 29, 2005 -
Nov 29, 2005 -
17 New Siliconix PowerPAK 1212-8 Power MOSFETs Offer Superior Thermal Performance in DC-to-DC Applications
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Vishay Siliconix Announces New PolarPAK Double-Sided Cooling MOSFETs news release has been viewed 1132 times
