Breakthrough Concept to Bond Circuit Board Jumper Wires
Nov 12, 2008
November 10, 2008 - Haverhill, MA � CircuitMedic's Flextac Wire Dots replace glues and adhesives with super-sticky tape specially designed and cut to permanently secure circuit board jumper wires. This unique wire tacking product consisting of pre-cut shapes of a thin, flexible polymer film coated on one side with a high performance, electronics grade permanent pressure sensitive adhesive. Flextac Wire Dots conform to the shape of the wire and the board surface providing a high strength bond to quickly and neatly secure jumper wires.
Flextac Wire Dots have excellent initial bond strength that will increase over 72 hours. They can be repositioned during and immediately after initial bonding without causing adhesive transfer or loss of bond strength. High humidity has a minimal effect on adhesive performance and bond strengths are actually slightly higher after exposure for 7 days at 90�F (32�C) and 90% relative humidity.
Flextac Wire Dots will hold securely after exposure to numerous chemicals including most flux cleaning solutions/sprays, saponifiers, solvents, mild acids and alkalis. Wires will hold securely through a typical circuit board hot water wash.
For more information visit: http://www.circuitmedic.com/products/310-2100.shtml
CircuitMedic is a division of Circuit Technology Center. Circuit Technology Center, founded in 1979, is the most innovative specialist in circuit board repair and rework. Headquartered in Haverhill, MA, the company's products and services range from base board repair and BGA rework to coating and mask repair. Circuit Technology Center is recognized as the country's most innovative specialist in circuit board repair and rework. The company is located at 135 Ward Hill Ave., Haverhill, MA 01845. Phone: 978-374-5000, Fax: 978-372-5700, Web: http://www.circuitrework.com.
Nov 13, 2023 -
Circuit Technology Center Announces New Component Trim and Form Service
Jul 19, 2023 -
Whitepaper Discusses Critical Process Steps for High-Reliability BGA Device Re-balling
Nov 12, 2021 -
Circuit Technology Center Releases Updated Bonding System
Aug 13, 2021 -
Circuit Technology Center Commissions New XRF X-ray System
Aug 09, 2001 -
Base Board Repair Kit Has �Everything Needed� To Repair Most Types of Damage to Circuit Boards
Jun 11, 2001 -
Professional Repair Kit, the �Total Package� for Repairing Damaged Circuit Boards
May 02, 2001 -
Update Operator Certification with the IPC 7711 Rework Skills Certification Kit
Feb 26, 2001 -
Flextac Self-Adhesive Stencils Simplify BGA Rework
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Breakthrough Concept to Bond Circuit Board Jumper Wires news release has been viewed 2282 times
