How does SMT solder paste affect soldering quality?
May 20, 2023
The flux mass ratio and composition of solder paste flux components:
(1) Film-forming substances: 2%~5%, mainly rosin, and derivatives, synthetic materials, the most commonly used is water-white rosin.
(2) Activator: 0.05%~0.5%, the most commonly used activators include dicarboxylic acids, special carboxylic acids, and organic halide salts.
(3) Thixotropic agent: 0.2%~2%, increases viscosity and acts as a suspension. There are many such substances, preferably castor oil, hydrogenated castor oil, ethylene glycol mono butylene, and carboxymethyl cellulose.
(4) Solvent: 3%~7%, multi-component, with different boiling points.
(5) Others: surfactants, coupling agents.
Influence of solder paste flux composition on soldering quality:
Tin bead splash, flux splash, ball book array (BGA) void, bridging, and other poor SMT chip processing and welding have a great relationship with the composition of solder paste. The selection of solder paste should be selected according to the process characteristics of the printed circuit board assembly (PCBA). The proportion of solder powder has a great influence on improvingslump performance and viscosity. The higher the solder powder content, the smaller the slump. Therefore, the solder paste used for fine-pitch components should use 88%~92% more solder powder content of solder paste.
1. The activator determines the solderability or wettability of the solder paste. To achieve good soldering, there must be an appropriate activator in the solder paste, especially in the case of micro-pad soldering, if the activity is insufficient, it may cause grape ball phenomenon and ball-socket defects.
2. Film-forming substances affect the measurability of solder joints and the viscosity and viscosity of solder paste.
3. Flux is mainly used to dissolve activators, film-forming substances, thixotropic agents, etc. The flux in solder paste is generally composed of solvents with different boiling points. The purpose of using high boiling point solvents is to prevent solder and flux from splashing during reflow soldering.
4. Thixotropic agent is used to improving printing performance and process performance.
Summary of solder paste affects soldering quality.
The above content is related to the components of SMT solder paste and the impact on soldering quality shared by the SZTech-SMT processing factory. I hope it will be helpful to you. To learn more about SMT chip processing, welcome to visit www.sztech-smt.com
Jul 10, 2023 -
How to maintain SMT machine?
Jul 10, 2023 -
How to inspect BGA solder joints in SMT processing?
Jul 10, 2023 -
What is the principle of AOI inspection?
Jul 10, 2023 -
What is the precaution for the SMT production process?
Jun 01, 2023 -
Precautions for SMT production line
May 20, 2023 -
What is the SMT process flow? Check SMT process introduction
May 20, 2023 -
What is the core machine of the SMT processing plant?
May 20, 2023 -
How to effectively store and use solder paste in an SMT patch processing factory?
May 20, 2023 -
What is the working principle of SMT reflow soldering?
May 20, 2023 -
What is the reflow soldering process requirement for PCBA processing?
14 more news from SZTech-SMT Firm »
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
How does SMT solder paste affect soldering quality? news release has been viewed 826 times
